NOTE:	It is highly recommended to first go through the Manuals on the Vital
	System Website especially before wiring!
LINK:	www.vitalsystem.com/hicon-oem#downloads
Mach4 Plugin Setup
* Make sure Mach4 is NOT running.
* Copy the "M4HiCON.m4pw" and "M4HiCON.sig" files to the plugins folder of your Mach4 install directory (EX. C:\Mach4\Plugins)
* NOTE: Check Axis output settings in Mach4 plugin config screen.  make sure it set to type "Stepper".
The current firmware version on your device may not be the latest. To ensure plugin compatibility, you may need to update
the firmware and FPGA as necessary.This can be done through the VSI Device Manager application.
Firmware Upgrade
* New firmware and FPGA files can be programmed using the VSI Device
  Manager application available from the Vital System Inc. website.
* VSI DeviceManager Download Link
  < www.vitalsystem.com/portal/motion/VSI_Device_Manager.zip >
* VSI DeviceManager Manual Download Link
  < www.vitalsystem.com/portal/motion/VSI_Device_Manager_Manual.pdf >
